1968 F100 2wd style side short bed.
Craigerf100
Re: 1968 F100 2wd style side short bed.
Post by Craigerf100 »
Got the hood on. I haven't adjusted it yet to fit snug but I'm kinda thinking my hinges are tweaked. I used a different set then my original ones. The hood is setting all kinked to one side. Added to the list of issues to resolve :roll:
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
pincheweddo
Post by pincheweddo »
Dude that 67 grill look sweet in flat black. I suspect it is going to get glossy but try the whole truck in gloss with a flat back grill before you do. I thinks you will like it. 8)
See project updates at:
http://1967f100.blogspot.com
Craigerf100
Good idea, I'm liking the satin black look a lot. :hd:
pincheweddo
Craigerf100 wrote:Good idea, I'm liking the satin black look a lot. :hd:
:thup:
Craigerf100
pincheweddo
Nice! Solid looking truck.
Craigerf100
Thanks :D
Craigerf100
Been tinkering with the truck a bit.
Last time I ran the motor I ran it at idle for a while to make sure she doesn't over heat.
Lo and behold it did. I am just hoping it's a stuck thermostat.
I pulled the thermostat last night and put it in HOT water. And I didn't see any movement. So i slapped the therm. Housing back on with no thermostat and sometime this evening After a night of the gasket sealer curing. I'm going to put the antifreeze back in and idle her for a while in hopes it was a stuck thermostat. :pray:
Then if all is well tackle the hood fitment.
Wish me luck
Craigerf100
Well I did all the above :yt:
The engine didn't overheat. But I only ran it for 15 min. Is that enough time for it get to operating temp? At idle.
Got the hood aligned but I'm stumped on something.
The hood lines everywhere nicely but the driverside fender. it looks like.... well I can't explain it. I'll just have to take a picture and post it here.
Craigerf100
Here's a pic of the fitment issue:
The rest lines up just fine:
It's like the fender is veering out from the cab:
here's the other side. Not bad
Craigerf100
Any advice would be great
HIO Silver
Post by HIO Silver »
I think adjusting the inner fender at the core support inwards plus adjusting the fender will suck in the fender...might require filing some holes.
pincheweddo
That is totally fix-able! Just not sure how. :hmm:
1. Try loosen in the bolts and pushing the fender in. My guess that won't do much.
2. Is where the fender aligns with the cab correct? Or can it be moved in ward?
3. Look down the inner fender on the flat port that slopes from the cab to the radiator support. Is it bent out ward?
HIO Silver
Update!?
Just wondering if the ol' girl got her body aligned and is on the road. Howz it going?
Craigerf100
Hey yeah life got in the way there for a bit. Yes and no on the body lines. Still got a few to adjust. I hope to have the exhaust installed the this weekend; after I figure out why my brakes are so soft. Gonna try and vacuum bleed my brakes and see if that helps.
Can't wait to drive it and feel that sway Bar in action.
