![Woohoo! :woohoo:](./images/smilies/icon_woohoo.gif)
- cdnwillyg
Well after a little massaging the front all came together, this was rewarding to see.
I started on the wiring now and in need of some info on the headlight buckets as to what spring/springs hold it in along with the adjustment bolts. These are the two springs I have in the parts not sure which one or if any are right.
Stony Plain, Alberta, Canada
:drive:Willy
:drive:Willy
- Manny
Man that thing looks fantastic!!! You polish the grille out??
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
I was looking at how your fenders are a bit wider than the hood. Are your fenders stock or reproductions? Mine are repos and stick out about the same as yours- I just aligned the hood so they stuck out the same on both sides. Aligning body panels is tedious.
Kyle
Kyle
- cdnwillyg
The grill was polished sometime in it's life but I had to clean it up in spots from being wrapped in wet newspaper for how knows how long.
The rock guard still needs a final polish but the bumper was re-chromed and is beautiful, a real good job done to it. I would have taken a straight on pic but I'm only 6" from my work bench and about 3" from my garage door....the truck can't grow anymore or it will have to stay outside.
I will be on the electrical for a while now trying to sort that out along with a few paint and body defects that need to be addressed.![Mad :x](./images/smilies/icon_mad.gif)
![Laughing :lol:](./images/smilies/icon_laughing01.gif)
:drive:Willy
:drive:Willy
- hfdco4
It is looking good as all the parts get installed. Wiring is always fun, take your time and based on your other work it will come out great!
FE390PC
![FORDification Rocks! :fr:](./images/smilies/icon_FORDification.gif)
- cdnwillyg
I think I have one original and one re-pop, and that's how both mine ended up and believe me I tried everything to get them right. I'm always looking now to see what other trucks look like and they all seem to be that way.Lone Ranger wrote:I was looking at how your fenders are a bit wider than the hood. Are your fenders stock or reproductions? Mine are repos and stick out about the same as yours- I just aligned the hood so they stuck out the same on both sides. Aligning body panels is tedious.
![2 cents :2cents:](./images/smilies/icon_2cents.gif)
Thanks hdco4, it would have been a little easier had I taken this truck apart and known the issues prior to getting painted as well. Yeah the wiring is not a big deal just need to check everything done and see what is missing.hfdco4 wrote:It is looking good as all the parts get installed. Wiring is always fun, take your time and based on your other work it will come out great!
![Hmmm :hmm:](./images/smilies/icon_hm.gif)
:drive:Willy
:drive:Willy
- 67mann
cdnwillyg wrote:Well after a little massaging the front all came together, this was rewarding to see.![]()
I started on the wiring now and in need of some info on the headlight buckets as to what spring/springs hold it in along with the adjustment bolts. These are the two springs I have in the parts not sure which one or if any are right.20180113_160812.jpg
http://www.fordification.com/tech/image ... dlamps.jpg
- cdnwillyg
Thanks 67mann, I did see that diagram but thought the spring was just a generic symbol as both springs I have are a little different.
:drive:Willy
:drive:Willy
- DuckRyder
Keeping in mind that mine is a 72, it has the springs with basically round hooks. I took a picture and will post after I stick a fuel pump on it..
- cdnwillyg
It has the same number so that is the one I will try first.
Thanks Robert.
Thanks Robert.
:drive:Willy
:drive:Willy
- Manny
Yeah think my bronco was the same way spring was the same side to side. ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- cdnwillyg
Tried them both and both seem to work okay, all sandblasted and painted
![Very Happy :D](./images/smilies/icon_biggrin.gif)
:drive:Willy
:drive:Willy
- hfdco4
Wow they came out great. What paint did you use?
FE390PC
- Manny
hfdco4 wrote:Wow they came out great. What paint did you use?
![Yeah that :yt:](./images/smilies/icon_yeahthat.gif)
- cdnwillyg
I have found that using Dupli Color High Heat engine enamel works best for me. Two reasons, one you don't need primer and two it dries to the touch in about 4-5 minutes which is good for me because I'm impatient. ![Laughing :lol:](./images/smilies/icon_laughing01.gif)
:drive:Willy
:drive:Willy
