1970 F100 Project
- hfdco4
Re: 1970 F100 Project
Fantastic Job, it will be a nice ride when it's done.
FE390PC
- 390bump
Fantastic job! Love the color!
- F100builder
hfdco4 wrote:Fantastic Job, it will be a nice ride when it's done.
Thanks guys! I love this color too! I was torn between this and lunar green...perhaps my '69 will be lunar green someday???390bump wrote:Fantastic job! Love the color!
Patrick
- 390bump
What do you do for radio reception if you delete antenna? Maybe they make a windshield with built in antenna?
- Mancar1
Outstanding work, truck is looking way
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- Calfdemon
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
- F100builder
I don't really plan on having an antenna or head unit of any kind at least at this time. I will be plugging an iPod or MP3 player directly into an amplifier.390bump wrote:What do you do for radio reception if you delete antenna? Maybe they make a windshield with built in antenna?
Mancar1 wrote:Outstanding work, truck is looking way.
Thank you!Calfdemon wrote:![]()
I know I am late to the party, but loving your build!! Love everything you have done so far. Great color and really liking the wheel and steering column!
Patrick
- F100builder
I spent many hours degreasing, bead blasting, and rebuilding the power steering box...on my [censored] counter!
I got a Borgeson 1"DD x 3/4"-36 spline rag joint to connect the ididit to the Sag. box. After careful measurements and mocking up the column, I tacked the dash mount bracket to the housing and let some paint fly. Also scored a prop. valve mount as well as some other odds and ends parts from the local pick 'n pull yard.
Patrick
- F100builder
I cleaned, blasted, and painted a bunch of brake stuff too! The proportioning valve, wheel cylinders, shoes, hardware kit, e-brake cables, drums, and master cylinder are all new parts (front brakes are almost brand new and were on my '69 before). Guess what my next project will be!
I've got all new stainless line to bend up and flare! I also scored a V8 gas pedal and linkage and a wiper switch.
Patrick
Very nice Patrick! What's that paint you used on the steering gear, m/c, and accelerator parts? Looks great!
- 67mann
Do you have the Bead Blaster between the fridg & dishwasher or next to the stove so you can flip the burgers while your blastingF100builder wrote:I spent many hours degreasing, bead blasting, and rebuilding the power steering box...on my [censored] counter!![]()
- jimmy828
Looks like someone is moving right along with their project and doing a great job on top of that!!
- F100builder
Thanks Randy! The paint is Dupli-Color engine enamel and the color is 'cast iron gray'. I typically use it on drums, master cylinders, steering gears, calipers, u-joints, etc...basically stuff that Ford didn't paint at the factory and then later turns to rust. I'm going for the 'restomod' look for this truck so I want a mostly stock appearance at a glance but with a few safety and performance upgrades as well as some aesthetic changes like wheels, a lowered stance, etc. Plus, I like a little contrast under the hood rather than shooting EVERYTHING black.sargentrs wrote:Very nice Patrick! What's that paint you used on the steering gear, m/c, and accelerator parts? Looks great!
Thanks! I actually put a few parts in the toaster oven to ensure that they dried thoroughly after the super hot, soapy bath in the [censored] sink! I've washed a few parts in the bath tub too!67mann wrote:Do you have the Bead Blaster between the fridg & dishwasher or next to the stove so you can flip the burgers while your blasting![]()
Very nice(as always) Patrick
Thank you! I wish my pace was a little quicker but I'm plugging away. I've learned to make more frequent but smaller goals for myself and that has helped me keep motivated.jimmy828 wrote:Looks like someone is moving right along with their project and doing a great job on top of that!!
Patrick
Thanks! I'll have to get some of that for my cast
parts.
- SATURN5
Looking good! I'm still stuck in winter here... The garage is a mess, I need to roll everything out and sort, clean and organize... Too much stuff, too little room. Meanwhile, getting up to speed on getting the 32V ECM harness sorted, ECM programmed.
Bob
68 F100 Flareside, CVIFS, Cobra IRS, DOHC, M122, MS3, T45, 4.10, Cobra brakes
84 Mustang SVO, B234F, HE351, Full Cobra spec suspension and brakes including IRS, T-tops
96 Mark VIII, Complete chassis bracing, 03 Cobra wheels, Maruader converter, built trans.
