Rebuilding a factory A/C unit - Done!
sargentrs
Re: Rebuilding a factory A/C unit
Post by sargentrs »
Remove the retainer plates and the heater core lifts out.
sargentrs
Post by sargentrs »
Congratulations! You have now completely disassembled a 1971 factory AC unit. Stay tuned while I refurbish everything and attempt to put it back together :lol:
sargentrs
Post by sargentrs »
One of my biggest fears was that my heater core would be bad. Everywhere I've read here says nobody remans them and I've been unable to find one in all the usual catalogs and websites. Plenty of heater only cores but no heater/AC cores. Not knowing the part number was a hindrance so I went to the Diagrams and Schematics section and looked at the exploded view of the unit. Know the basic schema of Ford part numbers led me to a Google search for "heater core" "-18476-" and down the rabbit hole I went. Google led me to an old Ebay ad for the core I need but referenced a Vista Pro part number 399038 and a Modine part number 702212 http://www.ebay.com/itm/361179250830. This led me to an Econoline forum where I guy said the Modine part number referenced part number C8UZ-18476-A or B but another Ebay ad and Rockauto search leads me to believe the Econoline core is too long. Sure enough, another google search and got a hit for a Vista Pro 399038 at RockAuto and I snatched it up for $12.97! Hopefully it's the right one :hmm: Here's what my core looked like when I got it out. If the Rockauto one doesn't pan out, and I fail to find one, I'll have to try to get it repaired. Looks like the PO tried to pull the unit out and forgot to unclamp a hose so it's bent over and crinkled into the top. Also pretty badly corroded.
1972hiboy
Post by 1972hiboy »
That would be quite a breakthrough if you finaggled a way to source the right heater core for one of these.......keeping fingers crossed its the correct one.
Rich
Dont eat yellow snow.....
sargentrs
Post by sargentrs »
Took a few more photos and found a part number on the thermostatic switch. While searching for sources guess what I find? http://www.fordification.com/partnos/ac ... tegral.htm Duh! Why didn't I look here first :doh: Sourced both switches NOS on Ebay for a total of $70. Probably could have shaved a few dollars off but the other web hits didn't look very promising. Now to find the blower motor resistor...
sargentrs
Post by sargentrs »
Ok, scored the thermostatic switch for $35. The other switch though was an auction starting at $25. I dropped out when the bidding topped $50. I refuse to pay that for a plain push button switch. I'll check out the one I have and see if it works. Got a call in to Wesley Obsolete on the resistor. Apparently the AC resistor is like hen's teeth. I'm sure the heater only resistor would work just as well and is more readily available? However, FedEx showed up today and dropped off the Holy Grail of heater cores! Allow me to introduce the Vista Pro #399038. :D
68RGR
Post by 68RGR »
Randy - Before you junk the original fan resistor, please measure the resistance of each coil. Having accurate info will enable folks to get "modern" resistors to replace them.
Also, if you can figure out the current drawn for each speed, a wattage value can be calculated for both resistors/coils.
With those values, each coil can be replaced with something like this:
Or this:
IGNORE THE VALUES IN THE PHOTOS - The photos are only meant to show the types of resistors that might be used to replace the originals.
Bill
68 F100 Ranger
73 F100 Ranger XLT
sargentrs
Post by sargentrs »
Thanks, Bill! I'll check the resistance next time I work on the unit. Any input as to why it's inside the case instead of mounted and covered on the outside? The heater only resistor is mounted to the interior as well. If it's only function is to serve as a fan speed regulator, why mount it so that it's inside the "hot box"? Could it be because it generates heat and they didn't want it warming things up under the dash, maybe? Since heat increases resistance, isn't that a "self eating knockwurst"? Things that make you go...hmmmm... :hmm:
sargentrs
Post by sargentrs »
Another search this morning turned up the A/C control switch for a NOS 69 70 Ford A/C Temperature Control Switch PN C9AZ-19A945-A. Looks like the only difference is the mounting bracket. Should be an easy retrofit. Got it for $27 including shipping.
1972hiboy
Post by 1972hiboy »
This is gold right here.......you figured out the heater core snafu congrats!!
Rich
sargentrs
Post by sargentrs »
Yeah, Rich, unfortunately, it appears to be the last one in existence. It was a wholesale closeout with 1 remaining at Rockauto. If you check Rockauto again, it doesn't even come up. So sad... :(
treverd
Post by treverd »
Sargentrs,
I appreciate you being so diligent in your updates and pictures. I will be attempting to swap a dealer installed AC from a 1972 Ranger XLT into our 1972 Ranger.
I am watching your progress closely.
Thanks,
Trever
68RGR
Post by 68RGR »
Randy,
Regarding the fan resistors - I suspect it might have been cheaper to build it "open" and then hide it inside the box. Additionally, when your unit is in COOL, the resistors will be cooler! Same could be said when non-A/C trucks are in VENT mode, I guess. The info on the resistors would make it very easy to come up with a universal pair of modern resistors that could be mounted remotely - Even on a metal surface, if they were the gold, sealed type, to help dissipate the heat they generate. Plus, you could customize the two lower speeds - If low was too low or medium was too high, you could change the resistor values accordingly. Going even further, it might be possible to have a variable speed fan! I'm no motor control expert but there almost has to be a way to do it electronically - Like with an SCR or similar device.
Bill
68 F100 Ranger
73 F100 Ranger XLT
sargentrs
Post by sargentrs »
Thanks guys!
68RGR, I'll get to those resistor values soon, I promise!
sargentrs
Post by sargentrs »
Teaser photo!
