Thank you so much. Tomorrow morning ill take a look at it. Just went to the DMV and got it registered again... So ill be able to tinker with it on the road more often (and legally)sargentrs wrote:I always use a vacuum gauge to set timing and tune a carb. Set/tune for highest steady vacuum reading at idle (around 700 rpm). I've gotten some really odd, unexplained, initial vacuum readings before. Then rev up to 2500 rpm and check your timing again. Should be around 35*-38* @ 2500 rpm. If now, advance until it is and let your initial timing fall where it may. Then try it out for driveability. There is no magic formula for timing. Each vehicle has it's own little problems/quirks that could affect it. My old 302, with 300,000 miles on her, ran great with max timing at 38*. However, when I got it set there, the initial came in at 22*. Seemed odd to me but she ran great that way.
Thank you so much for the link!! Been looking forever! And yeah I'm hoping not... But it could be. Never know with a truck that sat in a barn half it's life and on a farm the earlier half as a work truck. Thanks a lot. Ill keep that in mind.moonhanger007 wrote:http://www.fordification.com/forum/view ... 22&t=22303
Here is a link that should help with posting your pics. love the instrument cluster, great idea.
Just went through the timing issue with my truck, after new points and condenser, i pulled the timing chain cover ended up having a chewed cam gear.
Hope it's not that serious for yours.
Yes.... Kinda clanking sound like something was loose underneath but I was thinking it was a center support bearing that was ba so I was replacing it once it stopped raining. But then this happened... What's your idea or reasoning behind what is wrong?Stealth69 wrote:was it making noises any before?
