'67 SWB hotrod
- chad67
Re: '67 SWB hotrod
Yep, and since I got the whole assembly, I took pictures of where the combination valve and brake line brackets bolt on. I got everything off the frame section today after work. I got the I-beam bushings out by lighting them on fire until they got soft and then I just pushed them out with a screwdriver. Since the polyurethane replacements use the original outer shells, I saw no reason to press them out only to clean the rubber out and press them back in. Kingpins are next-never done them before-wish me luck. No glamour shots today-I was too greasy to use my camera.
1967 F100 SWB
- tylerb43
Re: '67 SWB hotrod
Looking good, man! Wanting to see pics of the whole truck though...
- chad67
Re: '67 SWB hotrod
Ya, I guess I could have posted some pics when I started this post-duh! I just noticed that you are from just up the road from me, tylerb. I work in Washington, MO, so I drive through Union every weekday.
1967 F100 SWB
- chad67
Re: '67 SWB hotrod
Here are some during shots.
1967 F100 SWB
- chad67
Re: '67 SWB hotrod
Here are some of my parts scores.
1967 F100 SWB
- ta TACO
Re: '67 SWB hotrod
Senior,
Lookin good. Are you going rat rod or are you going to another route? Can I have first dibs on the extra cluster you scored? I have been researching and found found these gauges made in the USA. http://www.speedhut.com/
These are pretty awesome! I have not done any reviews but, they are made in the USA and have a lifetime warranty, can't beat that!
Anyways, keep up the work, stay motivated and love wrenching!
Davin
Davin
68 F-250 CS, 360 or 390?, still haven't measured the stroke, AUTO running on propane!
- chad67
Re: '67 SWB hotrod
I don't know if I would call it rat rod, but it will have flat black paint-what you see in the pictures is actually primer. I don't have a shop, so in an effort to keep my yard from looking any more like a junkyard-I am getting everything in primer and trying to keep the truck in as few pieces as I can. Once it's all primed-I'll take it apart, paint, and put it together. I'm building a 408w stroker for it that I will disguise as best I can by making it look like Henry would have built (see my valve covers and air cleaner for a peek). I guess I just decide what I like as I go.
1967 F100 SWB
- ta TACO
Re: '67 SWB hotrod
Not familiar with the 408W. Is this built from 351?
Davin
Davin
- chad67
Re: '67 SWB hotrod
Yes, it's a 351w bored .030 over with a 4 inch stroke. I'll back it up with an AOD, and keep my stock 3.70 gears.
1967 F100 SWB
- Heirloom
Re: '67 SWB hotrod
chad67 wrote:Yes, it's a 351w bored .030 over with a 4 inch stroke. I'll back it up with an AOD, and keep my stock 3.70 gears.
Very similar to my plan, but instead of an OD I'm re-gearing to 3.54 and upping tire size a smidge. Oh, and not a 408W....a 408M....or is it 408C....or Boss 408
~Heirloom
~ Thomas Jefferson
~ Abraham Lincoln
~ Thomas Jefferson
~ Abraham Lincoln
- chad67
Re: '67 SWB hotrod
Since I do all my work outside, the seemingly constant rain has kept the '67 safely under it's cover. Got a little window of sun, so I disassembled my calipers and soaked them in toilet cleaner until they were rust-free. Then I shot them with some paint I mixed until I liked the color. I'll use this color on various pieces to break up all the black.
1967 F100 SWB
- chad67
Re: '67 SWB hotrod
The reason I'm selling the other intake is because I got this Victor Jr. It's had some port work done and is tapped for a nitrous fogger-which I will NOT be using.
1967 F100 SWB
- chad67
Re: '67 SWB hotrod
No "glory" work to report, but I did realize that my brain isn't going to cut it as an organizational tool. For that reason, I started boxing, bagging, and marking all the smaller parts I have laying around. Tedious for sure, but not as tedious as trying to figure it all out upon reassembly.
1967 F100 SWB
- Alstoyz
Re: '67 SWB hotrod
Hey bud. Did the F-600 you got your dash from happen to have it's front fenders still intact??? I'm look'n for some front fenders from a "bump" big truck.?.?
Thanx, Allen.
Thanx, Allen.
1970 F-100 SWB Tubbed
1971 F-350 4X4 (traded for 71 crewcab)
1971 F-250 Crew-Cab Dually
1972 F-100 SWB 4X4
1972 F-350 Crew-Cab 4X4 Dually
2001 F-350 Crew-Cab Short Bed 4X4 Dually
1972 F-100 SWB 4X4
- chad67
Re: '67 SWB hotrod
There were actually 2 F600's in the yard with fenders. I can't remember the condition, but I can check when I get back over there. Shipping might be a killer, though!
1967 F100 SWB
