Adding a 2nd battery for my camper.
- alvald83
Re: Adding a 2nd battery for my camper.
Are any inline fuses needed on the backup battery cables?
- alvald83
How would you incorporate a fuse panel for the camper, or would you just use inline fuses.
- 1972hiboy
alvald83 wrote:How would you incorporate a fuse panel for the camper, or would you just use inline fuses.
Your camper doesnt have a small fuse panel? Mine has one with only three fuse holders but its plenty for what is running inside the camper. I used a inline fuse in the main feed wire going to the camper fuse block. Just extra insurance if that wire found a ground somewhere I wouldnt fry the entire length of wire I have loomed under my truck into the camper plug.
Rich
Dont eat yellow snow.....
I installed isolator on mine. Bought it at a swap meet last fall for 15 dollars and it works fine. My older camper had the HD solenoid on it and it worked fine too. I moved the factory Camper Special wiring from stock battery to drivers side battery. I am going to add 3 12 volt power points to my camper. It will keep my phone charged and my 12 volt fans working if needed. I am also going to throw in a trickle charger in the camper in case I camp for more than a week end and 110 power is available.
1968 F250 Camper Special 390
1964 Galaxie hardtop 352
1967 Cougar project
1993 F350 Crew cab 5.8
1988 Bronco 5.8 C6
1966 Mustang fast back project
New 1962 Falcon Gasser project
1967 Cougar project
1988 Bronco 5.8 C6
