It has been a month and it seems like the time has just disappeard with VERY little to show for it... No pics in this post, but I will try to get some up today or tomorrow before I am gone again
I have come to some realizations - as a former restoration expert, my usual builds are slow and methodical, but when I am done they are perfect. I have never tried to work any other way, but I MUST do this one differently. Due to time constraints, I have to focus on getting the assembled and running by June 30 as I have to move. So you will see me focusing on those things that can't be done in a small garage in an HOA regulated community. Some examples are I have an NP205 I wanted to install, but instead will slap the working D24 back in - ugly, greasy and all, as I can rebuild the 205 and install it easily in a small garage. I can't do the body and paint... so that has to be done right. Same goes for the NP435... sadly, but it worked OK before, so I will just reseal it.
I say all that so when you see me bolting up a greasy piece of crap to this you don't think I am lazy or crazy... ; OK.. Maybe crazy...
Here is what has happened since the last update:
Cab is primed and the underside/firewall is in it's final semi-gloss Black (Hirsch's Chassis Black - same as the Frame)
Most of the small parts have been blasted/primed/painted and are waiting for reassembly.
Seat frame is blasted/primed/painted.
Front fenders are primed and bodywork done.
Inner Fenders are finished - same semi-gloss black.
Frame is back on the horizontal, putting axles under it. Since I am installing 79 D60's there is a lot of work to make them fit - especially as I am using some custom front springs - modified superduty springs. They were designed and sold by Cage offroad... I know the manager there and got a set before they closed and they have just been sitting around. You have to modify the front mount to use the 18MM bolt, but otherwise they fit great.
Took the 3 spare steering boxes I had and built 1.... hopefully it will steer well... if not I can put the original back in... as sloppy as it was.
Hung the transfer case... New bushings to keep it tight.
Took the rear driveshaft in and had it reworked and balanced.
Ordered $1000 worth of weather stripping from Dennis Carpenter... it may be pricey, but the best if you can't get Ford WS...
Anyway, that is about all I can remember... I will get pics up later.
