Emma takes the stand(s)
Re: Emma takes the stand(s)
just kidding
- Manny
robbkramer wrote: The whole thing is stout as hell that way and if you toss a hay bale off the top of a stack, for example, you can't dent the top rail of the bed . . . not that I'd ever do something careless like that, just saying![]()
MMMM hmmmm
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- robbkramer
Front drums on, finally!
Just the rears to go but I have to buy the correct seals (durn it). Then some brake bleeding will be required and then I can put her back down on her tires. Had quite an adventure getting the drums turned, but they are ready for some new miles now.
- Manny
Very nice there. Bet your ready to drive it.
- robbkramer
The hurry up and wati (for parts) is killing me . . .
Manny wrote:Very nice there. Bet your ready to drive it.
- BobbyFord
Re: Front drums on, finally!
You have the shoes reversed. The larger shoe (with more material) goes toward the rear.robbkramer wrote:Just the rears to go but I have to buy the correct seals (durn it). Then some brake bleeding will be required and then I can put her back down on her tires. Had quite an adventure getting the drums turned, but they are ready for some new miles now.
- robbkramer
Nice catch! Well, not too hard to fix that problem. I'd like to believe I'd have caught that but who knows! THANKS!BobbyFord wrote:You have the shoes reversed. The larger shoe (with more material) goes toward the rear.robbkramer wrote:Just the rears to go but I have to buy the correct seals (durn it). Then some brake bleeding will be required and then I can put her back down on her tires. Had quite an adventure getting the drums turned, but they are ready for some new miles now.
- BobbyFord
No problem
- robbkramer
Carb installed . . .
Rebuilt carb is installed. Re-routed plug wires since these photos were taken and have truck running now, even put the tires back on (brakes are bled--Mytivac bleeders are COOL). Tomorrow--if weather permits--carpet kit, headliner and seat plus some dash wiring issues. Almost there!
- robbkramer
latest image with wires re-routed
- robbkramer
- 72stepside
Where did you get the carpet? It looks sturdy!
Chris
72 F100 Stepside w/ 78 300 CID
Hedman Headers
Disc Brakes
Power Steering with 3 STILL on the tree
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Loooong way to go on this one!
Hedman Headers
Disc Brakes
- robbkramer
Here's the company I bought from: http://www.stockinteriors.com/AutoCarpe ... odelId=21072stepside wrote:Where did you get the carpet? It looks sturdy!
It's very sturdy and has a good, thick insulating backing glued to the primary area and a kind of silicon seal everywhere else. I have the 80/20 weave and it's good stuff. It also comes pre-molded to the shape of your truck's floor so it's an easy fit. Hard to cut the holes for bolts, etc.--get a super sharp knife--but manageable!
- 71PA_Highboy
Trick from the mustang shop I used to work at:
When placing a carpet, it is a good idea to let it sit and get warmed before you trim it. Once you have it in place, I like to take a 16P nail, heat it cherry red, and use that to perf any holes that I need in the carpet.
Since I am matching existing holes I can't 'slip' and cut too big of a hole, and the hot nail melts the carpet so it can't unravel if a nut or bolt grabs a loose thread. I especially like it for the seat track bolt holes.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- robbkramer
Awesome . . . wish I'd thought of that about 6 hours ago! My wife came out when I was nearly done and said "I should have heated up a knife or something so that wouldn't fray" --OK, so I did it the hard way!71PA_Highboy wrote:Trick from the mustang shop I used to work at:
Good advice!
