No, mine has a stock AM. I have a couple of stock AM/FM's and when I stick one of those in I will go to the two speaker set up, like you are doing.1971ford wrote:ahh i see.
But i thought the problem was that a stereo won't work with a single speaker setup. Or did you run that with an older radio?
speaker wiring
- BobbyFord
Re: speaker wiring
Re: speaker wiring
there I go thinking again. I told you the wrong site.
It is www.customautosound.com and they have the dual voice coil speaker.
- 1971ford
Re: speaker wiring
Thanks! Checking the site out now... they do have bumpside replacement dual speakers that go in the original dash spot!
One problem though, is they don't list the price, and i have a feeling it might be a bit out of my range, i guess i have to call!
-Ryan
- 1971ford
Re: speaker wiring
This would do the trick right? "dual voice coil" For bumpsides, i'm assuming it's a direct swap in..
This is a custom autosound, like mentioned in last couple replies.
http://www.metropartsmarket.com/catalog ... 52227.html
-Ryan
Re: speaker wiring
Yes!
That is the type you want, it has both channels hooked into it and is set up to use the larger one for the base and the two smaller ones for the stereo channels it is all setup internally just hook right and left wires from your stereo to it.
- 1971ford
Re: speaker wiring
if you get one of those speakers. let us know how it fits up under the dash and speaker bracket.
- 70_F100
Re: speaker wiring
Ryan, you might want to check this thread before you spend that money:
http://www.fordification.com/forum/view ... =6&t=57478
That's not an oil leak
- 1971ford
Re: speaker wiring
THanks for the link, definately interesting... I wonder if lmc gets there speakers through the place i was looking at. Either way i guess i need a plan B.
-Ryan
- 70_F100
Re: speaker wiring
If you look closely at the speaker magnet in that thread, the manufacturer is Custom Autosound.
- 1971ford
Re: speaker wiring
Tested my stereo on a buddies spare set of Fonix speakers, stereo works! And he gave me the speakers...
So now i have 2 good speakers and my stereo that still works. I was going to put the speakers in the kick panels (with carpet covering kick panel/speaker perimeter) but when i went to mark the drivers side kick panel to know where to cut the hole, i realized i forgot about the air vent thats there so i can't fit a speaker there nicely.
Question. Can I use my original in dash speaker paired with one totally different speaker? Then i'd have the original speaker in the dash hooked up with the new speaker in the passenger kick panel.
Can i do this? I'd like to get everything done tomorrow. Can't find any other place to put the second speaker.
-Ryan
Re: speaker wiring
Im not the wise guy on tunes in vehicles but seeing how my new Dodge Ram has 6 speakers factory an my little bro hooked up two extra speakers in his 95 XJ i dont see how it would be a problem. you could always call a local stereo shop an ask them a quick Q
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
ECV 1849
