Truck want start NEED HELP
htrooster4
Re: Truck want start NEED HELP
Post by htrooster4 »
I have tried both ways. I am going to try to go today or tomorrow and recheck all the cables. i Have a couple of diagrams that will help.If the starter is completely shot would it not even attempt to crank at all? Because i had replaced the starter a couple of years ago.(Truck doesn't get ran but 3-4 times a year) but i am going to Rebuild whole truck only 72,000 original miles.
forrestbump
Post by forrestbump »
htrooster4 wrote:If the starter is completely shot would it not even attempt to crank at all?
One way to know for sure, is to remove the starter and bench test it by grounding it, then "touching" the electrical post on it with a hot cable hooked to a known "good" battery. If it's "good", it'll spin over. Do NOT bolt the hot lead to the starter motor, just touch it with the hot lead from the battery, otherwise you'll "weld" them together. Ask me how I know...
Larry
htrooster4
Well i had removed it and went and got it tested at auto zone 3 days ago. The first time it failed the next 2 times it passed. I will try that tho forrest.
when i have starters and alternators tested. i use two different stores and get two different tests. one from each store. that way if both say bad then it is bad. if both say good then its good. when one says its bad and one says its good i go to a third and even a fourth place to have them checked.
Ranger72
Post by Ranger72 »
Thanks 390Bump!
I was able to get my truck out of the driveway using the hotwiring info.
Now to figure out why my ignition switch isn't working.
Steve
1972 F-250 Camper Special
390bump
Post by 390bump »
Great - now you can also steal the neighbor's truck if you have to :lol:
these switches and the soelnoids go bad. or it could be a loose wire. or a burnt one.
