How do you roll back an Odometer?
BobR
Re: How do you roll back an Odometer?
Post by BobR »
Hello Calfdemon
Thunderfoot helped me with mine. Follow his directions. Once I removed the pin and cogs, I then took a piece of masking tape and taped the the numbers to the position I wanted. Then you can replaced the red cogs one at a time and not loose the numbers position. Once the pin is in place remove the tape.
BobR
dj_trucks
Post by dj_trucks »
Sorry to bring this back from the dead, but I am currently trying to solve my own speedometer troubles. I had no trouble matching up my new-old odometer, just remove that pin.
fordman wrote:you can't go backwards only forwards.
Is this just for the f600 gauges? My f250 odometer will turn back when I drive backwards!
basketcase0302
Post by basketcase0302 »
My family had a 73' Pinto that did the same thing. You could actually take miles off the speedo by driving it backwards-ask me how I know! :lol:
bjde0b
Post by bjde0b »
I have dissaembled two different odometers and reassembled and they functioned normally. I don't recall it being overly complicated.
Whateverman
Post by Whateverman »
lol!my 75 pinto & 87 towncar did that too.....
- still got my first first car 20+yrs later : 69 f100 sorta kinda pretending its a Mercury M100 w/a 70 f350 sport custom cab (factory buckets) 67 grille with 69 ranger cooneyes 68 merc box and hood,some supercool fiberglass fenders i scored way back when, 76 f150 disc brake frontend..currently running a 90 5.0HO 4bbl/c4 auto & 3.50 posi...originally a 360/c6 f100 Ranger with dealer added towpack (incl. kelsey hays trailer brake),boxside toolbox,behind the seat stowage & belly tank...only original parts left on 'er are the frame,rear end,rear springs,and rear bumper...
67 Camper Special
Post by 67 Camper Special »
Thunderfoot wrote:Yes you can reset the odometer! I did it with mine. You have to drive the pin out that is holding those red gears, once removed you can roll the numbers. It takes a little playing with to get them lined up again so the red gears mesh up right so the alignment of the numbers looks right.
[ Image ]
I have done this as well. I like to start my old trucks at zero when I rebuild them just for kicks. Did it on a 72, have not done my 67 yet. When I sell I just sell as mileage unknown.
Larry
67 Camper Special Ranger
460/C6, PS, PB
Too Old Building Contractor
68 Ford Stepside
Post by 68 Ford Stepside »
In this state, tampering with a odometer can get you a big fine & if you're a registered car dealer you can draw some time down at the farm.
"Have A Great Ford Day"
bjde0b
Post by bjde0b »
" & if you're a registered car dealer"
Claim mileage unknown and you are fine.
67 Camper Special
I tear the tags off of my mattresses too! :wink:
Larry
460/C6, PS, PB
