No brake lights
Re: No brake lights
would the tail lights and turn signals still work if the tss is bad?
- Heathcliff68f100
Re: No brake lights
Yes, I had that problem, and it held me up for months, i tore the dash out and traced every wire, the switch had melted on one of the terminals, and so all i had was turnsignals and my left hand brake light, check the tss
1989 dodge b250 van, 239 v6 blown a904 tranny RIP
1968 ford f100 lwb l6 240 c6 tranny
Re: No brake lights
Thanks guys I will look at the tss tomorrow!
Re: No brake lights
Is this a problem that just showed up (was working before and now isn't) or is it a problem that came with the truck when you got it?
Re: No brake lights
67twinstang,
You definitely should get some kind of insulation around this wiring connection when done. Not too cool for underdash wiring to be left exposed like this:
Re: No brake lights
Thunderfoot wrote:Is this a problem that just showed up (was working before and now isn't) or is it a problem that came with the truck when you got it?
This is a problem that came with the truck.
Re: No brake lights
At first the brake lights and interior dome light would always stay on when the truck was running and I couldn't get them to shut off and now this.
Re: No brake lights
I removed the fuse yesterday right before I took the pic. I plan on replacing all the fuses today. which fuse is the brake light/hazzard fuse?
Re: No brake lights
Oh and I forgot to mention that my emergency flashers don't work either. I hate electrical issues
Re: No brake lights
It's the one right next to the dome light one. http://www.fordification.com/tech/wirin ... epanel.jpg67twintstang wrote:I removed the fuse yesterday right before I took the pic. I plan on replacing all the fuses today. which fuse is the brake light/hazzard fuse?
That doesn't surprise me, they are on the same power circuit and feed all the way up to the TSS via 2 separate routs but meet at the same location going into the TSS. So one of two possible issues still, either the power for it or the TSS.67twintstang wrote:Oh and I forgot to mention that my emergency flashers don't work either. I hate electrical issues
- Dragon
Re: No brake lights
And that jumper might be on that fuse because corrosion has caused the contact to fail behind the fuse holder where they are riveted together.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
My Gallery
Spark test
Re: No brake lights
Thanks for being so helpful guys! I haven't had a chance to work on the truck today. I will try tonight or tomorrow!
Re: No brake lights
I fixed the problem. Believe it or not the corroded terminals in the fuse box were the source of the problem.
So I cleaned up the terminals with some sandpaper and replaced the fuses. Now my brake lights and emergency flashers are working. Thanks for all the info and help.
