'67 F100 stepside - full resto new photos 03/03/2013
- 67nukeford
Re: '67 F100 stepside - full resto project storyboard
Looking good so far! I did the same, with the baggies and index cards. I also have a bunch of boxes for each are where the parts are from.
- 69F110
Looking good!
Steve Davis
Pastor and U.S. Army Retired
1969 F100 Ranger LWB, 390 and 3 on the tree
- tybob81
Remember to take lots of pics during the tear down so when it is time to put it all together you don't have to second guess yourself. I did and wish I would have posted it on photobucket too, because Wal mart lost my photos the developed!!
- 67mann
Doing a little target practice while working on the truck
looks like a good sized caliber---can't wait to get to my next place so I don't have to pack everything into the truck to go shoot
Moving right along on your progress---Are you going to strip down the frame and rust treat it
- stephen44
67mann wrote:Doing a little target practice while working on the truck![]()
and yes I am taking the frame all the way down and sand blasting it etc
thanks
Stephen
Stephen
- stephen44
so - it must seem like I have disappeared but I have slowly been rebuilding teh rust
here to remind you was what i started with
thanks
Stephen
Stephen
- stephen44
and here is where I am at..
thanks
Stephen
Stephen
- 72stepside
Those cab mounts look fine to me. Yeah, they are different that what I have in my project thread, but it looks like they'll work.
Chris
72 F100 Stepside w/ 78 300 CID
Hedman Headers
Disc Brakes
Power Steering with 3 STILL on the tree
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Loooong way to go on this one!
Hedman Headers
Disc Brakes
- 69FLATBED
Dang Stephen, that was a fast teardown!
keep up the good work.
Troy
_________________________
2000 F350 4x4 Crew Cab PSD
1969 F350 Flatbed 360 4spd DRW
!968 F250 4x4 Crew Cab SWB
Love my diesels hope to be gasoline free soon!
- stephen44
good - thank goodness for that72stepside wrote:Those cab mounts look fine to me. Yeah, they are different that what I have in my project thread, but it looks like they'll work.
- Stephen
thanks
Stephen
Stephen
- stephen44
69FLATBED wrote:Dang Stephen, that was a fast teardown!keep up the good work.
thanks - as I am finding out - the tear down is the easy bit
- Stephen
I got guns - paint & filler delivered today - so I can see light at the end of the tunnel
-(as the old joke goes - let's hope it isn't a train
thanks
Stephen
Stephen
- stephen44
Re: '67 F100 stepside - cab corner replacement - pics
I thought I'd document how I did this - as you cannot buy the inner corners - and this might help someone as I could find no hints on the best way of doing this. Now remember - I have no metal working experience - so i am not saying this is the right/best way of doing this - but this seems to have worked for me.
this is what i started with (other side)
i decided to butt weld - as i knew i could get to both sides - I took the cut too the point of good metal and since the replacement part did not fit exactly - just shy of the mold line.
thanks
Stephen
Stephen
- stephen44
I then welded and ground both side
I made the inner corners from the left over outer corner - I flattened it with the BFH
- for the beading on the original inner corner - i cut back to good metal and then slit the beads and flattened to give me an edge to butt weld.
I epoxied all the insides to give them some protection before welding on the inner corner.
I shaped the edges over a wooden table and a stone paver
thanks
Stephen
Stephen
- stephen44
I continued shaping till I was happy with the fit and then welded up
I kept on welding until all pin holes had been sealed and then ground down
thanks
Stephen
Stephen
- stephen44
Re: '67 F100 stepside -cab corner replacement - pics
I also started sanding the cab down
thanks
Stephen
Stephen
