Ok, my latest project was to repaint the hood, which was covered in surface rust, and the tailgate, which came from a different truck and so was the wrong color.
I actually started this project last June.
, but then got sidetracked for the next nine months. I bought automotive paint in an aerosal can from two places. The first was paintscratch.com and the second was autopaintdirect.com . The cans from paintscratch.com were very expensive, something around $30, while the paint from autopaintdirect.com was $14 per can. However, I think the color was a little closer with paintscratch.com. I will note, however, that I had the paint from autopaintdirect.com sitting around for several months, so it is possible that had some negative effect on the color match.
Anyways, here is the process and results:
I started with the hood in this condition:
I used a 3M paint removing wheel on my drill and some 80 grit sandpaper to remove most of the paint and rust. Here is half way through:
Very dirty under the F-100 reflector:
After I got most of the paint and rust off, I took the last little bit off with steel wool and Navel Jelly. Here are the results:
Not a bit of dirt
I primed with SEM self etching primer, which a member here recommended
These were the results last June. I had a lot of very "dry" looking spots on the hood and I wasn't really that happy with the results:
So this March, I sanded the hood with 320 grit sand paper, then 600 grit and got a pretty smooth surface. I gave the hood another couple of coats. Overall, I'm satisfied with the results. It definately is a 20 footer, but it will have to suffice until I get it professionally painted in a couple of years.
Here is the before and after on the tailgate. I didn't bother to fill the couple of holes in the tailgate because I don't have a welder and I figure I'll get it done right when I get it professionally painted.
Now I have to do something about that bumper!
I really tip my hat to anyone who can paint well with an aerosal can. It is pretty tough.
