wiring it up...
re: wiring it up...
the 69 diagram (charging system diagrams) have me all confused. it shows the orange that i have, not plugging into anything at all...but it has an orange colored wire coming from the fuel tank sender, to a cylinder labeled "F", which I can only guess is some sort of fuse, then going to a plug block connector and then to what im guessing is the plug I see. Am I seeing that right?
I don't really see any black/red pig tails?
Red and black to back up, purple to brake warning and you are missing the pigtail cables that go from up high at those connectors to another connector down by the places where they go. The cable is 3 pieces for each one. inside to firewall/fender connector cable from connector firewall/fender to frame down by the brake warning valve. Pigtails from there to the actual switches.
re: wiring it up...
where exactly ARE the switches?
- customcrewcab
re: wiring it up...
in the dash?
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
re: wiring it up...
see I didn't see anything in the dash that didn't have a plug, and if it did, it was connected to something else. I will look harder in the morning.
I'm guessing it would be easier if I pulled the gauge panel out as a whole and looked.
- customcrewcab
re: wiring it up...
oh i think he talking about the switch valve. do you have any wires going the the brake light switch on the pedal?
re: wiring it up...
the one that when the brake isn't pressed, it presses the white button on it? if so, yes. that is plugged up. there is another plug that seems like a lot of wires, like a 10 pin connection with 9 pins only, something like that. thats connected as well.
- two-bit
I'll take a look at my '72 tomorrow and see if i can help you out on wiring ID.
Going to an auction in the AM.
So i prolly won't be until the afternoon.
Two-bit
Two-bit
Living life full throttle on the North Coast of America!!!
72' F-350, DRW, 360, NP435, Dana 70, 159" WB, P.S., P.B., 12' flatbed, 10,000 GVW.
re: wiring it up...
they probably belong under the dash just a fair warning haha.
re: wiring it up...
I found them
They were up under the truck, had dropped down around the tranny area. Thanks guys.
No I just need to figure out that orange wire!!
- rjewkes
the one inside the cab goes to the fuel tank. the one under the hood goes on the alternator i believe it is the feild, or it may be te stator wire.
re: wiring it up...
huh? The only one left is the orange wire, and I don't have anything (that I can find) to hook it up too.
- rjewkes
is it the long orange one inside of the cab?
if so it goes up through the pillar over the door down the back pillar and onto the fuel tank sending unit. all on the driverside.
if its the one under the hood it goes to te altenator.
- two-bit
re: wiring it up...
OK, went out a looked at my '72 F-350.
The Orange wire you speak is the one that comes out of the harness by itself and has a black female style barrel shape plug on the end of it?
If so, my truck also has the same wire. It is connected to.....
nothing.
On my truck it just hangs there and does nothing. Everything works fine elec. in my truck. So i would say, don't worry about it.
Good luck
Two-bit
nothing.
Good luck
Two-bit
