neutral safety switch-HELP!!
DuckRyder
re: neutral safety switch-HELP!!
Post by DuckRyder »
You can order them from Ford. They will probably make you buy two, and I think they are about 12.00 each.
They are some sort of springsteel and just have two hooks that latch into two holes in the shift tube. Pretty easy to install if a bit awkward with it in the truck.
It will be pretty obvious when you get the new one.
bugly truck
Post by bugly truck »
Robert,
thanks for the info...i will see if my local dealer can hook me up...whoops, that didn't come out sounding quite right :lol: :oops: :eek:
I mean my local Ford Dealer!!!
Ken
qman
Post by qman »
Yep, I'm positive it's that easy. It doesn't bolt in or screw in. There are two holes in the column right in front of the neutral safety switch. The part is Y shaped and the two ends just snap into those two holes. You don't need to remove anything. You may need to adjust the positioning of the switch from side to side once you put it in so that it's held in the correct position. The holes for the hold down screws are elongated to allow for this adjustment. Go here and it's item (D) on page 25.
http://www.dennis-carpenter.com/pdf/67-72Truck2006.pdf
$22 seems a little steep. I got mine for like $6-7 from the dealer but that was 6-8 years ago.
72 F100 2wd 360 C6 Custom w/factory PS.
yea 22 is kind of high. ford does sell them in pairs for 37.99 therer is one at laird noland ford in topeka kansas for 18.99. it was still available as of 12-20-06 the part number DOTZ-7B097-B from the dennis carpenater catalog.
rjewkes
Post by rjewkes »
I have a spare one you could have for $5.00 bet that'll cover shipping too.
Did yours break or just pop off the colum?
