Hello from Ok!
A place for new members to introduce themselves
F250MudPatrol
re: Hello from Ok!
Post by F250MudPatrol »
Hey whats up? I'm here in Norman. I am currently rebuilding a 1971 F-250 highboy, white. I hope your project comes along well. If you need any help, let me know. It's always good to see another Okie on here. :D
The truth shall set you free.
wt4speed#2
re: Hello from Ok!
Post by wt4speed#2 »
Welcome from Texas
Tony B
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
Aubrey
Post by Aubrey »
That a/c is called a 270 a/c. Roll 2 windows down and drive 70 for cooling.
333 is tatooed on my head. I'm only half evil.
Aubrey
More pictures of Buellah at http://s94.photobucket.com/albums/l108/ ... h_69_Ford/
hossw71SportC.
Post by hossw71SportC. »
Welcome from Kansas
I got inlaws and a Uncle in Tulsa
Get-R-Done
71 F100 Sport Custom
99 F250 Powerstroke
Dropped 68
re: Hello from Ok!
Post by Dropped 68 »
Welcome from Wichita!
dbarker
re: Hello from Ok!
Post by dbarker »
Thanks everyone for the welcome. Always good to see people offering help on a common subject.
After joining I've been reading a few things here and there & have done some research on my truck to verify a few things.
I previously mentioned i have the under bed dual saddle tanks, mounted outside the frame rails. These tanks are IDENTICAL to the ones pictured here: http://www.fordification.com/images/FAQ ... _small.jpg
The gas tank write up, http://www.fordification.com/fuel-tank01.htm , says this:
"Here's another example of some dealer-installed auxiliary tanks, also commonly know as 'saddle tanks'. These plastic tanks have no visible filler on the outside of the truck because each tank's filler neck is located inside the rear wheelwell. (I'm not sure if these are equipped with sending units....I'll check into it.)"
To my knowledge as ive never put gas in the tanks, there is no sending unit on these. I have no way of switching tanks for the gauge other than my 3 way valve on the floor.
I plan on keeping triple tanks, and securing a way to have sending units available. I've even thought up a way to make a Factory Tank switch using a known part for 2 tanks & just adding a second switch to the mix.
At anyrate, the site is paying off already. Hope my truck can help others out. Remember, it is Unmodified from the day it came home from the dealer. and is only dealing with surface rust. I can look things over to answer questions that might be had if someone has a hacked up truck.
Wes
re: Hello from Ok!
Post by Wes »
Hey and welcome,
You've found the best board for our old trucks.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them :)
mrung0wa
re: Hello from Ok!
Post by mrung0wa »
:wel: :fr: :clap: :yt: 8) :hi: :wel:
Welcome my FORDification Brother!
You'll find that this is the best place where the best people hang out!
Like I always say "This place is better than Disneyland!"
Lawrence 8)
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
binder56jd
re: Hello from Ok!
Post by binder56jd »
:wel: from south central OK :thup:
now serving #235
