Thanks! I don't think you can go wrong with either one.e6ug wrote:Nice!! Starting to think i should have bought rustbullet instead of por15.
Thanks Randy! As much fun as the tear down is, it definitely feels better going in the opposite direction!sargentrs wrote:Congratulations, Patrick! Another milestone reached.
Thank you!67nukeford wrote:Awesome build! Truck is looking great!
Thanks!dantheman71 wrote:Great job on the antenna/fuel filler deletes. I've always been a fan of the "smooth" look.
The old cab mounts? I had to cut one of them up to patch a part of the floor with one of its 'ribbed' pieces.Craigerf100 wrote:Ill take them off your hands
It's a TCI kit from Summit. I believe it's the exact stuff they use in their 'Streetfighter' transmissions and includes a shift kit. I also installed a new one-way clutch bearing, new thrust washers, and new bushings that were not included in the kit. If I remember correctly, I got those additional parts from Broader Performance. I have a new Hughes torque converter (2200-2400 stall) and a new flex plate as well.schwefel69 wrote:F100 Builder where did you buy all the Parts to freshen up/rebuild that C6?
F100builder wrote:It's a TCI kit from Summit. I believe it's the exact stuff they use in their 'Streetfighter' transmissions and includes a shift kit. I also installed a new one-way clutch bearing, new thrust washers, and new bushings that were not included in the kit. If I remember correctly, I got those additional parts from Broader Performance. I have a new Hughes torque converter (2200-2400 stall) and a new flex plate as well.schwefel69 wrote:F100 Builder where did you buy all the Parts to freshen up/rebuild that C6?
