I got the heater controls all set to run the vintage air GEN IV. I took two top halves hooked them together, after flipping the lever, welding the cable bracket so it went the opposite way .Then took the cable pins off the heat defrost lever drilled holes in temp levers and pressed them in.
I needed a five pin fan switch to use Vintage Air's mustang conversion circuit board. I bought one off ebay that was listed for our trucks the lever on the switch was about 1/2" too long so I redrilled the holes in the bracket and moved it back.
So in the end all this will be hidden behind and the controls will look stock. Except now I really want to re-letter the face plate.
