Any suggestions on removing a broken bulb?
derek7871
Post by derek7871 »
Both parking light bulbs on my '68 Ranger will not come out. The glass part of the bulb has become unattached from the metal part that attaches to the socket. I figure I'll have to break the bulb and then try to get the metal part out. Does anybody have any wisdom or advice?
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
after removing power from the circuit, break out the glass and use a pair of needle-nose pliers to bend/remove the metal casing. easy to do.
and BTW :wel: to the site! there's lots of technical papers and info in the links at the top of the page for you to drool over!
derek7871
re: Any suggestions on removing a broken bulb?
Post by derek7871 »
Thanks. I was hoping it wouldn't be too much of a headache.
390Nut
Post by 390Nut »
What he said, and afterwards, use a bit of emery cloth or fine sandpaper to clean up the corrosion that's sure to be in there. A little dielectric grease goes on every bulb I replace, now. Used sparingly, it keeps the moisture out of the contact areas quite well.
Paul
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!" :thup:
Fake Name
Post by Fake Name »
If you have a wine cork, you can usually cram it in enough to get a bite. The grease when reinstalling is key.
fn
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
SmokeyBear
Post by SmokeyBear »
a potato works too.
70 F-100 XLT
"Christine" Gone but not forgotten.
72 F-100 Ranger XLT
derek7871
Post by derek7871 »
Thanks for all the great ideas. I will give them a shot this weekend and I'll let ya'll know how it goes. Thanks again!!
Joe Kriston
Post by Joe Kriston »
I'm dying to know which one worked....
This is the point...I'm....talking about everybody! I'm talking about form! I'm talking about content! I'm talking about interrelationships! I'm talking about God, the devil, hell, heaven!!!! Do you understand???? Finally!!!!
derek7871
Post by derek7871 »
I finally found time to remove those bulbs. I know ya'll were are the edge of your seats waiting. Anyway, I ended up breaking the glass and using a pair of needle nose to get the metal part of the bulb out. Thanks for the advise.
