SPEEDDOMETER SENDING UNIT HELP
- cooltoolguy
re: SPEEDDOMETER SENDING UNIT HELP
ain't goona work that adapter is for a chevy th350,700,or 400!
72 Ford F-350, 2WD, 4 speed 360, Dump truck
76 Ford F-350, 2WD, Cab and Chassis <--gone
No,i was told there is only two sending units and i have both ! classic ins. sent the ford one to me after the gm unit , can some one send a pic of a break down ?
- DuckRyder
Looks to me like you need this one:
SN16FRD
SN16FRD
- DuckRyder
Yes that is the Part Number, found it here:
https://www.classicinstruments.com/prod ... ode=SENDER
Looks to me like its possible to use the sender with a factory cable. (perhaps for a Cruise Control application or something.)
One would assume it can either be plugged or is sealed from transmission oil (which makes sense) and can be left open? I would probably just throw a big vacuum cap over it and call it good.
ROB ,THAT IS THE PLAN, i did go the there web and seen the sender you would think they would send the right part the 2nd time around , and i took there word that there just two types gm & fmc , service after the sale! Thanks you save me some stichs on my head ! THINK THINK THINK P.S. Have a nice easter! eric
