1995 460 fuel pump question
Gaslight
Post by Gaslight »
I am putting a 95 FI 460 into my 69 F100. I have already converted it to carburetor. I was OK with thinking I was going to have to use an electric fuel pump. But I started thinking about just putting a mechanical pump onto the 460. I cannot find any information on whether the eccentric is on the camshaft on this engine and hooking up a mechanical pump is just a timing cover and go. Or is it more involved?
Anyone have any knowledge on this?
Jake
1969 F100 Ranger
DuckRyder
Re: 1995 460 fuel pump question
Post by DuckRyder »
I should say i don't have much experience with Lima Motors, but most Fords have a eccentric bolted onto the front of the cam.
my guess is that adding one would be as simple as a longer dowel pin and perhaps bolt to add the eccentric. You should double check me.
I hope there aren't 142 different timing covers line a SBF. :eek:
