no key
no key
i got a parts truck with no key. i know how to take the key cylinder out with a key but i don,t have one and i would like to salvage the ignition switch if i can. does or has anyone been able to change the cylinder with out the key. i don't know if i can pic the lock like i can on house doors.
mrsnicks
re: no key
Post by mrsnicks »
From what I've found out and been told, without the key it's VERY hard to remove the cylinder. (Theft deterrant and all).
I belive the only options available to you are
1. buy a new ignition switch and cylinder
2. call a locksmith
Get a couple more opinions, and as always,
Just my :2cents:
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
FORDification
Site & Forum Admin
Site & Forum Admin
re: no key
Post by FORDification »
I don't know who's been telling you it's hard, but it's far from hard....of course, this is assuming you have the key. :P All you have to do is stick a stiff wire into the small hole on the face of the tumbler to release the tumbler from the housing. However, you have to have the key to turn the tumbler since it'll only release in a certain position (Start?)
Without the key, about all I could suggest is in agreement with mrsnicks....take the assembly to a locksmith.
yeah i will try to pick it myself i just want a backup switch is all i want. but i have to get the tumbler out to do that. otherwise it's worthless. and a locksmith would be more than just buying a new one.
TheEskimo
Post by TheEskimo »
Okay, so I can be VERY distructive at times. But couldn't one just use a drill and carefully remove most of the center, just enough to get to the tumblers and get the keyed part to turn so the little hole would line up for the removal?
Just a random thought at 1:20am
-Jason
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
yeah they do drill locks its only pot metal under the chrome. i didn't even think of that
rjewkes
Post by rjewkes »
also if you have an old worne out key. My old key wouild start three ford p/u :lol:
fuelly.com
i tried every ford key i had.
mk
re: no key
Post by mk »
Don't know if you have the switch out of the truck yet but I've found that the chrome bezel will clear the cylinder when turning it out. That way you can get the switch out and put it in a vice for the necessary 'surgery'.
mike
