connector on the dizzy
wire colors dizzy connector one side
wire colors dizzy other side.
Duraspark module 4 pin connector wire colors.
thanks for thoughts.
It's not only vacuum advance, there is no mechanical advance under the plate. The computer does all the advance work electronically. That distributor is pretty much only a shaft that drives the rotor and a flying shutter wheel for the pickup, no moving parts inside.Zorm wrote:my427stang, your are exactly right, kick my own butt, there is no vac on this dizzy. duh!! its going back for a correct one.
