PaPa's 69 F100 Explorer Coyote 10R80 swap
Venomous duck
Re: PaPa's 69 F100 Explorer
Post by Venomous duck »
You are welcome. Found a few more for the passenger side liner to firewall.
Venomous duck
And 2 more
Venomous duck
Its been several weeks since my last update but I'm still moving along. Here I am in the process of removing the cab from the frame.
Last edited by Venomous duck on Sun Nov 10, 2019 12:49 am, edited 1 time in total.
Venomous duck
cab off
Venomous duck
The frame is ready for engine removal
Venomous duck
Here is the 302 and 303 transmission on the ground. I don't intend to reinstall either of them.
Venomous duck
I thought I would show a couple of pictures that may be helpful to others. This is how the springs that hold the e brake cables are attached from the factory. I would imagine that many times these are missing or not installed properly.
Venomous duck
One last one
Venomous duck
Showing 50 years of grease and grime that needs to be cleaned.
Venomous duck
Here is the replacement 390 from my parts truck. 75 Ranger XLT Trailer Special.
Venomous duck
I had to tear down the engine to make it light enough for my small tractor to lift it.
Venomous duck
Here I am removing it.
Venomous duck
Here the engine is on the stand and then Mocking it up in the frame.
Venomous duck
I decided to make the transmission cross member removable. Here is a method that I use to remove rivets. Cut a cross in your rivet head as deep as possible without cutting into your frame. Then use your air chisel to cut the head off. Cutting the relief in the head weakens it and your chisel will go through it very easily. You can also cut it in to pie slices for even easier removal.
Venomous duck
Fitting the fuel tank. This is the kit from LMC. Its hard to see in the picture but the tank is not square.If you look closely at the left side of the picture, which is the front, it is made at an angle. The flanges are square just not the tank itself. I had to trim the cross member to the front of it up to a quarter inch to make it fit. I really can't recommend this installation. I think flipping and moving the rear cross member then installing a mustang tank is a better option.
Last edited by Venomous duck on Sun Nov 10, 2019 12:05 am, edited 1 time in total.
