my creampuff is missing the passenger side metal door panel.
only ones I can find that are factory have 6 inch speaker holes cut in them.
anyone here do this? it has the factory am radio in it, but i would like an am-fm radio.
need opinions...thanks..
speakers in door...67
- travlinjohn
Re: speakers in door...67
The 67 came with the AM radio and it was installed in the dash with built in mounting brackets. If you want to keep the originality of the 67 you can buy after market radios that are placed in other locations like under the seat or in the headliner. There might be a radio online (E-Bay?) that will fit without modifying the dash. I haven't researched the topic that much.
"Laugh Hard, Hang Tough, Lend a Hand"
- cdnwillyg
67 if you look at '68 they came with the AM/FM option that uses the same radio bracket. You may need to move the bracket forward on the dash support about 2" easy fix.
Stony Plain, Alberta, Canada
:drive:Willy
:drive:Willy
sounds good
thanks
thanks
