72 F250 4x4 Restoration
- popeyes71
Re: 72 F250 4x4 Restoration
Yeah, don't jump the gun to quickly. Even if you didn't do the upgrades that are being mentioned and where looking for original replacements you'll be ok. If you were closer, I've got a good Dana 24 transfer case and a good closed knuckle Dana 44 from my 71' Highboy that I would let go very reasonably. Just be patient, those items are relatively easy to locate even at a reasonable price.
-Popeye-
1971 F-250 4x4 Highboy
- hfdco4
We have all been in this same situation before. What you need to do now is this;
1) Inventory what you have between the two truck.
2) Figure out what you need to put the 4x4 back together.
3) Use the parts you are not going to use as bartering material or sell for funding your project.
I can tell you this has worked for me, and I do like being able to share parts with the group here.
Paul
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
FE390PC
1970 F250 4x4
- Bullitt74
This is looking to be a very cool build! Sounds like you got the right guys chiming in to give you helpful advice. Looking forward to following your progress!
Steve F.
Red Deer, Alberta, Canada
- DuckRyder
Check the pinion angle if you use the 2WD rear end, you might have to use some wedge shims. I’ve heard varying stories about whether they are the same of not.
Sorry guys - no photo updates this weekend - it’s raining:(
Question though? What’s the value of an old FE shortblock?
And is there anyway to identity if it’s a 360 or a 390?
- hfdco4
On the crank there will be a 2U or 2UA stamp for 390, 2T or 2TA for 360.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
You will find the number on one of the counter weights, just spin the crank and take pics for us!
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- Ranchero50
Just measure the stroke. 3.5 = 360 Longer is bigger.
- Manny
Engine doesn't look bad at all. Still curious to see the differentials. If the look like that you better be driving tomorrow
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- popeyes71
Yeah, measure the stroke. That will tell you right away what you have.
-Popeye-
Sunny and 55 this weekend!!! Sounds like it’s diff teardiwn and photo time!!!!
- popeyes71
Looking forward to hearing how things go!
-Popeye-
Rear end photos
Front end photos
