Windows stuck - no roll
Last fall, I successfully swapped out the door locks and Ignition tumbler with a new key on my '68. Few days after- the passenger-side window stops once rolled down about an inch, but roll back up. The truck has been sitting most of the winter and it now seems as though the drivers-side window will not roll down at all. Is there something obvious within these doors that causes such a thing? I'll be tearing them back apart regardless, but thought I'd ask.
- 69Ford
Re: Windows stuck - no roll
did you take the arm rests off before this happened. What happened to me is when I put the armrests back on the screws went to far in and when I rolled the window down about an inch it hit the armrest screw and stopped. loosen up the screws this may be your problem. Let us know.
- jzjames
There used to be a "how-to" for rebuilding the windows on this site, but it's no longer there. It was an older magazine article w/ pictures if I recall.
I think Kieth might have put it up.
It had older pictures of the disassembly, re-assembly, and was the best "how-to" I had seen.
Does anyone have the link to it?
maybe the plastic window rollers have broken. they're cheap and easy to replace.
- colnago
My windows lift out of the bottom tray, and get jammed in the tracks. If I hold the window down while rolling the window, it works fine.
Joseph
Joseph
I know which one you're talking about. It was a Dennis Carpenter write up, I believe. Keith did one too. http://www.fordification.com/tech/doors01.htm (thanks, Keith!)jzjames wrote:There used to be a "how-to" for rebuilding the windows on this site, but it's no longer there. It was an older magazine article w/ pictures if I recall.
