battery drain..
Junior Knight
battery drain..
Post by Junior Knight »
something keeps draining my battery causing it to have dead cells.everything under the hood is new so my question is... do I have a ground problem? How many grounding straps do I have on my 67 F-100 and where are they located? Thanks for the help! :?
1967 Ford F-100...goin back *STOCK*..just sayin
1972hiboy
Re: battery drain..
Post by 1972hiboy »
Charge the battery to get the cells back up. Your going to need a good charged battery for testing. The short story to start going after this is your going to need a good quality digital multi-meter. unhook the neg battery cable and hook the meter in line and see what kind of drain you got with everything switched off and doors close etc etc. From there with something of this age you could pull one fuse at a time until the drain goes away or reduces significantly then explore that circuit. I dont think your looking for a ground problem. aftermarket stereo electronic ignition added on the truck? those kinds of things do draw a little bit more so aftermarket stereo with keep alive. how fast of a drain are you talking?
Rich
Dont eat yellow snow.....
cep62
Re: battery drain..
Post by cep62 »
:yt:
But... on our old vehicles (this won't work on newer stuff) ,if you don't have a volt meter , you can use a test light in line with the Neg cable .
the brighter the light the bigger the drain . :2cents:
Mach428
Re: battery drain..
Post by Mach428 »
I would first charge the battery and take it to a good auto parts store for load testing. It may just be a bad battery, regardless of age
Junior Knight
Re: battery drain..
thanks for all the input..this is the 4th new battery this year...all had dead cells..all from auto-zone
Mach428
Re: battery drain..
Post by Mach428 »
Tell you my experience. I have had tremendous problems with these so called quality batteries from AZ, Pep Boys, etc. I bought a Duracell from Batteries Plus (yes they sell car batteries) no more problems. None
Personally I have never heard of a drainage problem that caused multiple dead cells. I would check for parasitic drain as mentioned and then decide if the battery is a cause or a victim
Ranchero50
Re: battery drain..
Post by Ranchero50 »
I agree. If possible, fully charge the battery and let it sit as long as you can disconnected. That should prove or disprove the battery being good or bad. Next on my list is the alternator. Unwire it and let the truck sit long enough to see if the battery is dying.
You have a current drain problem, not a ground problem.
Junior Knight
Re: battery drain..
thanks will do that..
