My truck just has a pefect hole, apparently I had one of these and it was removed at some point. IDK how to even search for this. So what exactly is this thing, what purpose does it serve? My truck had an auxillary fuel tank which was removed years ago so my thought was that it was somehow related to that. Thanks in advance!!
Casey
What is this?
What is this?
- SeapineF37
Re: What is this?
yep you are right. thats whre the selector valve for the fuel line went. allowed you to manually control which tank the fuel was being drawn from. probably was removed when the aux tank was eliminated...
1972 F350 seapine green cab/chassis drw
only one who has learned much can fully appreciate his own ignorance. louis l'amour
- 69Ford
Re: What is this?
Fuel tank selector valve. Your truck came with duel tanks.
Re: What is this?
Sorry that this is unrelated to your question but would you mind sharing where you got your dash/gauge set up, do you like it, and how did you set up the speedo? Thanks in advance.
