Fuel gauge
tlcat
Fuel gauge
Post by tlcat »
I restored a 1976 f150 with a 460, I replaced both tank level senders but cab gauge does not work gauge does not move when I ground sender wire, where can I get a diagram, I have looked everywhere
Montana71-F100
Re: Fuel gauge
Post by Montana71-F100 »
Yours is a '76 and this forum is for '67-'72 this diagram is for a '72 but it may help: http://fordification.com/tech/wiring_1972master.htm
The forum for your truck is: http://fordification.net/
mulletmobile
Re: Fuel gauge
Post by mulletmobile »
Sorry for the silly question, but I am just learning the finer points of vehicle electrical. How do I ground the sender wire to test it?
tlcat, did you find a resolution? I am suffering the same problem and trying to narrow the problem down.
1971 F-250, Wimbeldon White, 360, PB, dealer add-on A/C (A.R.A. brand), 1970 coded interior (23 - Med. blue/Light blue) with 42,000 miles.
Russell J
Re: Fuel gauge
Post by Russell J »
Not sure if you've taken a look at this...
http://www.fordification.com/tech/fuel- ... -units.htm
mulletmobile
Re: Fuel gauge
Russell J wrote:Not sure if you've taken a look at this...
Russel J,
Perfect! Thank you! As you can see 8 am relatively new to this forum. I have not had the time to check out all of the nooks n crannies for great info. I have been mainly checking for info on problems I have had via search and researching in the other areas as time permits. This one, however, is a gem. Answers all my questions on the gauge issue and using my meters. Thanks again!
