still having trouble with gauges working right..
- Junior Knight
new fuel gauge,new regulater on the back of cluster,wired right, i am at a wall...none of the others are doing right....
1967 Ford F-100...goin back *STOCK*..just sayin
Re: still having trouble with gauges working right..
Checked power to the new regulator? Fuse blown? Connections bright and tight? Good grounds? Lots of possibilities. Good luck. DanJunior Knight wrote:new fuel gauge,new regulater on the back of cluster,wired right, i am at a wall...none of the others are doing right....
1971 F250 360 3.73 Gears C6
- Junior Knight
done all of that...thanks for the info!
- carnuck
How about grounds at the sensors? Especially the fuel tank. Rust between the tank and straps messes the ohms up. Missing/corroded battery negative to body frame and cab? Bad ground in the dash?
Like my Aircraft Technical Systems E/E instructor told me 40 years ago, "Power is switched on and off, but ground is forever or else the pilot is put under it!".
- Junior Knight
well...found the problem...the float..
- Junior Knight
ok..all gauges working but the fuel gauge is not showing fuel level right. How do u adjust it to show right level of fuel?
