Windshild wiper arm removal?
Godspeed128
Post by Godspeed128 »
Can anyone tell me how to remove the windshild wiper arm on a1967 F100
Re: Windshild wiper arm removal?
Under the arm, to the inside, you'll see a little locking tab. Use a screwdriver and pry down on it, pulling it out and down. Once it's unlocked, you'll be able to wiggle it off. Probably have to lift the wiper off of the windshield to take the pressure off and let it be perpendicular to the shaft. Helps to place a small piece of wood under the back of it so you can pry up the rear gently with a screwdriver at the edge while you lift the front.
Godspeed128
That worked thanks for your help
