Replaced flashers but turn signal still doesn't flash
- timmk21
Here's the deal. All turn signals light up but don't flash when signaled. I read up and figured all I need to do was replace the flasher but that did nothing. Any info would be greatly appreciated. Thanks
Re: Replaced flashers but turn signal still doesn't flash
Are you sure you replaced the flasher for the turn signals and not for the hazards?
1967 F-100 4x4 custom cab.
- timmk21
I replace the one below the steering wheel column to the right. Where is the other one located at? I could only find the one.
On my 67, the one for the turn signals only is attached to the back of the instrument cluster with a small built in 2 prong retainer on the flasher. I can't remember where the hazard flasher is.
- timmk21
Yup that's the one I replaced.Busboy wrote:On my 67, the one for the turn signals only is attached to the back of the instrument cluster with a small built in 2 prong retainer on the flasher. I can't remember where the hazard flasher is.
