e150/250 cable with spring changed to a lighter shorter one.
same cable both sides it is 4" shorter than orginal cables so I extended the rod .
I have explorer rear disc brakes on my 9" rear. So that end of it is stock. The part from the cab to the lever on the cross member is stock except for the bracket that bolts to the frame under the cab. I had to shorten that and weld it on when i boxed the frame. I extended the stock adjuster rod I think about 4" . The cables that run to the rear are stock 2006 E 150 -250 I see if I can Find part number .I had to swap the heavy spring on the end of the cable with a lighter one from advance auto.IN2FORD wrote:Do me a favor and explain your emergency brake setup some more?
Barry
