Hey Everyone,
Haven't posted in a while, but I recently got a 70 F250 highboy Single cab LWB 4x4. I would like to put a 390 in it with a C6. Maybe eventually go to a 3.9 4cyl Cummins later on (just a thought).
My question is: I have 390 and a 2WD FE C6 setup already, but can this be put in the truck and have a divorced NP205 behind it? Or do I just go snag a full 4WD setup from another truck in the junkyard?...
Also, i would like to put disc brakes on the front and Ive heard rumors of people saying the front axles from a 73-79 f250/350 can fit. Is this a direct swap?...
Thanks guys,
1970 Ford F250 Highboy questions
- eggman918
Re: 1970 Ford F250 Highboy questions
The axle is a direct swap,when I did the 4bt swap I used a M5 then upgraded to a ZF transmissions both 2WD so I "think" that 2WD C6 should work as well.
Steve
The"Filthy Beast"- '68 F-250 Crew Cab 131"W/B 4x4 4BT compounds hx30/Wh1c,5x.012" sac injectors/ZF 5/NP203-205 /3.54 44 trutrack front/60 trutrack rear on 33's. 2nd owner
"Beauty is only skin deep....Ugly is to the bone"
It is more important to understand what you don't know than what you do know,because then you can start to learn..???
"you must deal with the attaboys and the ass chewing s with your head up and looking them in the eyes" T.J.E. aka My Dad
There are only three types of people wolves, sheepdogs, and sheep. What are you?
- 1972hiboy
I purchased a 70 f250 4x4 a couple years ago for parts but the previous owner installed a c6 behind a 390 and is using a divorced 205 so yes it can be done. not sure about the intermediate driveshaft from the trans to the t-case. may have to make something.
Rich
Dont eat yellow snow.....
- eggman918
I would count on needing a different length intermediate shaft,also the C6 has a slip yoke.I would plan on $300.00 for a new shaft,but you might find a good used shaft that you could shorten to fit that would cost ~half of a new one.
Steve
- popeyes71
Highboy bumps that came with an automatic C6 have a special tail housing that allows you to mount the gear selector for the transfer case. So you may need to locate the tail housing or a C6 from a 4x4 Bump. With that different tail housing, I'm not sure if that changes the output shaft length?
-Popeye-
1971 F-250 4x4 Highboy
67-72 highboy's come from the factory with automatics ? I didn't think the auto was a option in a highboy until 73.popeyes71 wrote:Highboy bumps that came with an automatic C6 have a special tail housing that allows you to mount the gear selector for the transfer case. So you may need to locate the tail housing or a C6 from a 4x4 Bump. With that different tail housing, I'm not sure if that changes the output shaft length?
- 1972hiboy
hazelnut wrote:67-72 highboy's come from the factory with automatics ? I didn't think the auto was a option in a highboy until 73.popeyes71 wrote:Highboy bumps that came with an automatic C6 have a special tail housing that allows you to mount the gear selector for the transfer case. So you may need to locate the tail housing or a C6 from a 4x4 Bump. With that different tail housing, I'm not sure if that changes the output shaft length?
Im pretty sure you could special order one with a c6. Not alot of them out there but I have seen a couple that people swore up and down thats the way it was when their grandfather got the truck.
Rich
Thanks for the info everyone. Glad to know it can work with some modifications so Ill start getting the parts together and see what I can do for mounting. As for the front axle, Ill try and grab one out of the junkyard from a 4x4 f250 dentside with disc brakes.
I think I remember reading something on site saying it was a option for 6s. I'd like to find a highboy auto in the junk yard to take the transfer case shift mount from1972hiboy wrote:hazelnut wrote:67-72 highboy's come from the factory with automatics ? I didn't think the auto was a option in a highboy until 73.popeyes71 wrote:Highboy bumps that came with an automatic C6 have a special tail housing that allows you to mount the gear selector for the transfer case. So you may need to locate the tail housing or a C6 from a 4x4 Bump. With that different tail housing, I'm not sure if that changes the output shaft length?
