The item between the battery and the starter solenoid, pictured below is on my 1967 F250 2wd. it appears to be factory original but I dont see it in the wiring diagrams...any insight would be appreciated.
what is this thing?
- SoCalRefuge
what is this thing?
SoCalRefuge
~67 F250 390~
~67 F250 390~
- HIO Silver
Re: what is this thing?
Horn relay
... honk the horn. Unplug the plug. Attempt to honk the horn again.
Ta-dah.
Ta-dah.
Horn relay.
1967 F-100 4x4 custom cab.
- jimmy828
Glad the pic was posted. It tells me exactly where to mount the horn relay when i get ready. Thanks!
- SoCalRefuge
Thanks a lot. This is perfect timing as my next project is to rebuild the horn swich in the steering wheel. The truck has been in the family since I was born and I have never heard the horn.
If you need more location pictures let me know.
SoCalRefuge
~67 F250 390~
~67 F250 390~
- Dan
Huh....I think I don't have that on my 67...and that's probably why my horn has never worked! Thanks for posting that, I'll check that out. I tried years ago to get the horn working at the steering column, but I'm not sure I even have a relay at the moment.
- duaneo
Replacements are easily available at the auto parts store. You might want to cinch down that solenoid cable while you're under there. That's a fire waiting to happen.
-Duane
-Duane
1971 F100 - Ugly on the outside, but purty under the hood...
1968 Chevrolet Impala - Family car since 1970, My car since I was 16, in need of bodywork/paint, but otherwise straight.
2004 Mini Cooper S - Daily driver and grown up go-kart
- SoCalRefuge
duaneo
I had to go back and look at the picture to see what you were referring to regarding a fire hazard. Thanks for the call on that. It was tightened down when I had everything hooked up.
SoCalRefuge
~67 F250 390~
~67 F250 390~
- SoCalRefuge
I ordered a replacement today. Seems there are two versions. The only difference is one uses 2 bolts to hold it on, the other uses 1 bolt (like in the picture). The 1 bolt version was $5US cheaper.
SoCalRefuge
~67 F250 390~
~67 F250 390~
