not starting
shawn
not starting
Post by shawn »
im having problems starting my 70' f250, it wants to start but as soon as I turn the key from the strting position to the on position it dies
FORDification
Site & Forum Admin
Site & Forum Admin
Re: not starting
Post by FORDification »
That's usually the sign of a faulty ignition switch.
cep62
Re: not starting
Post by cep62 »
Or the resistor wire , check for power to the coil with the key on.
shawn
Re: not starting
Post by shawn »
Power is going to the coil when key is on but not when key is in starting postsion
1970FordTK
Re: not starting
Post by 1970FordTK »
I know it sounds odd, but on the starter solenoid there are two small wires that connect to small posts. The brown wire on the one to the fire wall side of it is a booster wire to the coil when starting. I had a solenoid go out on me and it would short through that wire and caused the truck to not run once the key left the starting position. If you will take that wire off the solenoid and the truck will start and run. Well you need a new solenoid, if not you have to keep looking but its one of those things you can check that doesn't cost anything but time. :)
HIO Silver
Re: not starting
Post by HIO Silver »
shawn wrote:Power is going to the coil when key is on but not when key is in starting postsion
What troubleshooting has been done?
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
