I turn the key then...
mjhaltom
Post by mjhaltom »
My starter solenoid clicks and all my dash lights go out and there is no more power to anything. I wait a while and the solenoid resets then same thing all over again. Solenoid is good. Seized starter? Last time I ran the truck all was well and I parked her...?
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
Busboy
Re: I turn the key then...
Post by Busboy »
It sounds to me as though you have an intermittent open circuit at one of the battery cables or possibly inside the battery itself. You should be able to pinpoint it with a voltage drop test when the problem is occurring.
1967 F-100 4x4 custom cab.
mjhaltom
Post by mjhaltom »
So test between the battery posts and then at each post and the other end of the cables?
1989 Ford F150
Busboy
Post by Busboy »
Voltage drop tests are when you put the positive lead of the voltmeter at the positive battery post (not the battery cable) and then while the circuit is in operation or attempted operation, you sequentially move the negative lead of the voltmeter along the circuit until you see a slight voltage reading. This indicates a difference in voltage between the two test points which is to say a difference in pressure caused by loose connection, bad solenoid contacts etc. A good battery connection will show .2 volts drop across the connections. Notice the point 2 volts, not 2 volts! So with the positive voltmeter lead at the battery positive terminal, you would then move the negative test lead to the positive battery cable, then the starter solenoid input stud, then the starter solenoid output stud, starter stud etc. You can also check the ground circuits in the same way. Good luck and keep us posted. :thup:
mjhaltom
Post by mjhaltom »
Thanks. I need wiring for dummies! Stay tuned
1989 Ford F150
kato_pup_dog1977
Post by kato_pup_dog1977 »
The easiest thing to do (and affordable for those without a voltmeter) is to clean all connections very well. This includes the grounds too. Once clean, reconnect and try again. If same problem then swap batteries or jump start the rig. If that starts it, buy a new battery. If not, then buy a tester and find the open short. Most electrical problems are from a bad ground.
ford76460
Post by ford76460 »
Check the Starter Relay and the connections on it. I had the some what of the same problem. A faulty starter relay and the positive terminal cable were to blame.
mjhaltom
Post by mjhaltom »
Bad ground wire to the battery. skinned wire back and put on a clamp on stlye terminal. problem solved.
1989 Ford F150
