Speedometer Question
Eric46
Post by Eric46 »
My truck is a 1970 F-250 4x4 - NP-435, Dana 24 T-Case - with no speedometer reading. I disconnected the speedometer cable from the T-Case and spun it by hand...its good. I pulled the driven gear out of the t-case...it is not plastic, rather it is a metal gear (20 teeth)...and the teeth are worn off. The drive gear appears ok and spins when the driveshaft spins...looking through the hole in the t-case.
I didn't see in the 1970 shop manual where the speedometer cable attaches to the t-case. Were the 67-69 trucks different than the 70?
Any ideas where to find a new driven gear?
1970 F-250 4x4
Madman
Re: Speedometer Question
Post by Madman »
No.....they are the same for a D-24. You are looking at the correct spot for the transfer case (on the back side of the T-case going to the rear drive shaft).
If the teeth are worn off of it, sounds like it wore out (due to misalignment?)
""Never shoot a large caliber man with a small caliber bullet."
2017 Ford Raptor
1970 F250 4x4
1948 Willys CJ2A w/ Ford Flathead V-8
1975 Ford Bronco
Eric46
Post by Eric46 »
Yea...I don't think it was turning as one side is ground flat. Any ideas where to get another gear?
1970 F-250 4x4
The fastest way to get a gear is the local parts store. Then check online vendors for our trucks. As welll as ebay rockauto etc.
dftuttle
Post by dftuttle »
Try these guys. I have bought Speedo gears from them after making gear changes in the past.
Their info is very detailed & their gear calculator works well too.
http://www.transmissioncenter.net/speed ... ____va.htm
If common sense was really common, wouldn't everybody be using it?
