System is over charging
Bob Wakeman
Post by Bob Wakeman »
I have a 1951 rat rod ford pick up with a 1973 ford 302 engine. The battery blew up because of over charging. Charging at 16 amps. I replaced the Battery, Alt, And Voltage regulator. Still chargin at 16 amps. Where do I look from hear.
BobbyFord
Re: System is over charging
Post by BobbyFord »
I would look into the wiring. For some reason, it's not getting regulated voltage.
1972 highboy
Post by 1972 highboy »
could be a bad ground
1972hiboy
Post by 1972hiboy »
Well, 16amps is nothing to be worried about, so im going to assume you mean 16 volts. Which would be a problem. You should double check your wiring to whatever spec you have to make sure everything is where it needs to be. If wiring checks out. I would start going after grounds. its possible the alternator itself lost its ability to ground to the chassis, motor mounts by themselves are often not enough. you can test by taking some jumper cables and hooking onto the alternator body and the frame and seeing what happens.
Rich
Dont eat yellow snow.....
