WHAT IS THIS? 72' F250 Camper Special
mineros
Post by mineros »
Trying to take pictures, but dont know how to upload on mobile.
So right next to the little round BRAKE light on bottom left corner of dash, there is a knob, or whats left of one (it broken off). There are two wires, a black one with a fuse, which leads to the black harness (idk what you call it, but its the black box where all the wires leading to the lights are attatched to) right behind the lights switch, and a gray one leading to a small light bulb at the base of the steering column. ANY IDEAS??
Mancar1
Re: WHAT IS THIS? 72' F250 Camper Special
Post by Mancar1 »
May be where the emergency flasher has been located.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
