head lights -parking-side lights on hood
fy549
Post by fy549 »
69 Ford F100 truck ---does the headlights and the lights on each side the hood burn at the same time.I know when you cut on the parking lights,when you pull head lights on the parking lights go out,like they should.Just don't know about side lights on hood
69Ford
Re: head lights -parking-side lights on hood
Post by 69Ford »
There is no side lights on bump hoods unless somebody installed them just reflectors 68-72 67's did not even have reflectors. Here's pics of 69F250 Hood reflectors
fy549
Post by fy549 »
I have a 69 with side lights on each side of hood -----someone could have put them on-I don't know they were on the truck when I got it.and they do have lights in them
69Ford
Post by 69Ford »
fy549 wrote:I have a 69 with side lights on each side of hood -----someone could have put them on-I don't know they were on the truck when I got it.
Any Pics I'd like to see them Thanks
fy549
Post by fy549 »
Don't have any pictures looks like they drill a hole in the back of the metal,that goes on the back side of the lens,and drill a hole in the hood so then they put a bulb in it-----took it off hood and you are right it was made,they did a great job on it.
HIO Silver
Post by HIO Silver »
EZ... the reflectors have a foil backing. Remove the foil or carefully cut a hole and mount a 73-79 side marker light pigtail. An alternative is to simply meld a 73-79 housing with the 68-72 reflector.
fy549
Post by fy549 »
Got lights wired up it looks great at night with the lights burning in the hood-wire them so they burn with head lights on.
fy549
Post by fy549 »
got the lights working they look great burning at night wire them so they burn when the head lights are on-might go back and wire it to the turn signals so it will work when I uses the turn signals.
fbomber100
Post by fbomber100 »
:nopix:
