Rear Brake Light Bulb Type
Subzero
Post by Subzero »
My passenger side rear brake light is out and I need to change it to pass inspection. I don't have the truck at my house, it is at a shop which I go work on it after my day job at another shop. I don't know what bulb it takes and the truck being so old I'm not sure AutoZone would know either so I want to be sure I can buy the bulb during lunch and go directly to work on the truck. Does anyone know a bulb type for the rear brake light? Thanks
Mancar1
Re: Rear Brake Light Bulb Type
Post by Mancar1 »
It is a 1157.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
