need some some help 68 f100
shibbby911
Post by shibbby911 »
i drove my truck to the gas station today and on the way back it jus shut off all the sudden. then i had a buddy try to jump start me but as soon as we took the jumper cables off it would jus die.. then we could never get it started again after that.. could this be a bad generator? i did notice when we were messing with the truck and the idle would get low the alternator light would barely start to come on.
Mancar1
Re: need some some help 68 f100
Post by Mancar1 »
Sounds like a bad alternator. Have the alternator and battery checked. If they check good u may have a bad ground.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
shibbby911
How hard is it to go from a generator to a alternator?
Mancar1
Post by Mancar1 »
It is a fairly easy process. You can Google how to do it. You can buy new or get what you need off a donor vehicle. :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
shibbby911
Ok thanks I'll see what I can find
Mancar1
Post by Mancar1 »
shibbby911 wrote:Ok thanks I'll see what I can find
You can do it, but if needed I will try and answer any ??? There are also others on here that know more about the swap than I. I am sure they will chime in. :thup:
Keep on Trucking...John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
