horn question 67
Dinoeater
horn question 67
Post by Dinoeater »
I am trying to get the horn working, I am replacing the turn signal switch. There is a tower in the switch, what is the thing that goes in that tower that rubs on the ring in the steering wheel and where can I get one?
tac
Re: horn question 67
Post by tac »
Take a look at the Macsautoparts.com and see if this is what you need C2OZ-13A821-AR. It's called horn ring contact brush. I'm sure LMC and Dennis Carpenter have them also.
67mann
Post by 67mann »
:D I will also offer that if the missing part doesn't get the job done....there is a metal connector on your steering coupler(rag joint)that often breaks....that is important to grounding your horn :thup:
