All the bulbs work. When I test the power coming into the circuit board it reads at 14 V. When I test the wire at the temp sending unit In the engine compartment it only reads 2.3 V.
You can see a section that someone attempted to repair just above the IPVR. When I test one of those solder points, they both read 2.3 V. Before I started messing around with IPVR the volts to the temp sender was only 0.6. I turned that small knob on the IPVR clockwise until it basically bottomed out. Now 2.3 is the best I'm getting. I've tried grounding the gas sending unit wires and the needle does not move. I haven't tried with the temp gauge yet.
My assumption is that either the IPVR, the printed circuit board or both have gone bad. Any suggestions on more troubleshooting or what to replace first?
