I have a 71 F250 4x4. The in-cab tank came out of another bump vintage truck...i don't know what. The Fuel gauge sending unit came with the "new" tank. The "new" tank i had to drill mounting holes in it to mount it. When i have it all hooked up and lift the sending units float all the way to imitate full it only moves the fuel gauge to about half.
Ideas?
I am betting there are two different style sending units but i don't know.
Fuel Gauge and Sending Unit...not registering full
- KRob
71 F250 4x4, 4BT Cummins Mostly Done...Project Thread http://www.fordification.com/forum/view ... 22&t=65450
(4BT, big block ZF5, 78 NP205, 78 Dana 44 Front axle, 4.10, 265/75/16, power steering, power brakes)
01 Dodge 2500 4x4 Cummins...turned up a little.
- tbone6
Re: Fuel Gauge and Sending Unit...not registering full
Here ya go... http://www.fordification.com/tech/fuel- ... -units.htm
t6
1972 F100
1972 F100
- KRob
Thanks Tbone6 appreciate it.
Should have checked there first.
- KRob
Did a quick check this morning and grounded out the orange wire to the ground, guess what fuel gauge went all the way to full.
I will try to pull apart latter on today, to see if i can adjust it at all.
Otherwise my local parts house doesnt have them so i guess its off to LMC or Dennis Carpenter.
LMC is about 50 plus shipping....ouch.
