Ammeter gauge question
69Ford
Post by 69Ford »
I redid my headlights with a wiring harness kit that takes the power from the battery directly by using two relays. Relieves the switch by not running so much power through it. My question
is before I did this I could see a slight deflection in the Ammeter gauge when I turned the lights on and off. Is this because the power is not run through the truck system anymore and directly
off the battery. I know 90% of these gauges do not work but I actually had mine working before this. The reason I did this is because I was having the same problem as someone else with a
post out there right know headlights going out once and a while and flickering. Halogen bulbs may draw to much for old switch. Thanks
fmartin_gila1
Re: Ammeter gauge question
Post by fmartin_gila1 »
Sounds like the setup is working properly. Only the very small amount of current needed to activate the relays is going through the Ammeter. If the relays are fed from the battery, the current being passed will not be shown on the Ammeter.
Fred
tbone6
Post by tbone6 »
:yt: Well put!
t6
1972 F100
69Ford
Post by 69Ford »
Thanks for answering my Question. With out this site I probably would have sold my truck.
